Home > Maintenance & Modifications > Changing Gear Knob and Stick
coxman
I am planning to change the gear knob and stick for my landy. After consulting a few garages, they reckon to take off lots parts. Any idea what parts to be removed? It costs HKD 2000 (approx. 200 quids) for labour.
appreciate for any removal sequence so that i can DIY.
Post #578867 19th Nov 2016 4:12am
Likeomg
Which model defender?
on a puma, the main gearstick is a 5 minute job, transfer leaver is the tricky bit...
Post #578868 19th Nov 2016 4:51am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Puma transfer lever is easy too - sharply pull upwards and off it comes. No need to touch anything mechanical 😉 Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #578886 19th Nov 2016 9:25am
Mo Murphy
If its not a Transit Defender then the gear stick will come out by undoing one M10 nut. Lift the rubber gaiter and you will see it.
HTH
50 Shades of Pennine Grey
Post #578917 19th Nov 2016 12:15pm
coxman
mine is a 110SW year 2013
the mechanic said it has to removed the whole gear stick section
Post #578951 19th Nov 2016 3:19pm
Stiff1
He is correct in that you remove the whole gear stick... but it is very straight forward. See the sticky at the top re gear stick rattle.
As for the transfer lever, it does just pull up, although you may need to pull harder than you think you should, it will be fine.
Post #578964 19th Nov 2016 4:40pm
