![]() | Home > Td5 > Injector seal replacement |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Been thinking about getting mine done, how many hours labour were you charged for the job??
about 2 hr max id-say having had sum practice now x 2
It's not that bad a job, last time I did mine was on a camp site at Bala, I think the only reason it took around the 2 hours was because all the rest of the camping party wanted to come over and see how it was done
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Not sure how many hours it was, but it was £180 which included a change of oil too which he supplied. As mentioned, I supplied all the bits including both oil filters. Maybe this is over the odds, I don't know, but it is outside my skill level and he's the local Landy guy so he got the job.
Anyone have a rough idea how long this lasts before needing done again? What about the wiring harness, I've heard of people making it a service item and doing it annually? |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 981 ![]() ![]() ![]() |
Should last 100k Kms at least. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Mine was done around 120K and soon after by me as the eejit that did it used the cheapest he could find then again last year which was just under 180K. It's on 192000 miles now with no issues.
drakes Member Since: 09 Oct 2009 Location: Consett Posts: 115 ![]() ![]() ![]() |
Roddy I see you are in Inverclyde, what was the local garage that you used as I am trying to find someone local to use
Keith |
Keith,
I took it to my usual garage in Gourock and he took it up to the lad. I will find out what the other place is officially called and get their number. Cheers, Roddy. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3263 ![]() ![]() |
I wanted to get the injector seals done on my TD5, but none of the local places wanted to do it, as it is running OK.
"You're opening a can of worms" said one, and "they might not re seal" plus "you might end up needing a new head" The main dealer said l could end up with a bill for £3,000 and one of the lndys said they "didn't like to touch them" I might do it myself. Is it easy to get the injectors out? The local lndy charges £50 to recover a broken Landy from a customer's drive! |
this will good idea of how involved it is
http://www.discovery2.co.uk/Injector%20Seals.html |
Keith / drakes. The place is called 'The repair centre' and the number is 01475631618. The lad that done it is called Andy. Give him a call and he should be able to sort you out.
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Why, if things are okay, do you want to get them done? Are these things guaranteed to fail at some point? |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
I sold my Td5 with nearly 250,000 miles on the clock. It had a three exhaust manifolds, a new turbo, was on its third intercooler, its fourth fuel pressure regulator and innumerable injector harnesses. But the injector seals were never touched and it ran just fine.
If it's running okay with no symptoms of anything untoward, my advice is to leave it well alone. Dave Green Goddess - 1998 Defender 110 300tdi |
Totally agree wth that sentiment. The old adage of if it aint broke... seems to apply to most LR issues.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
