Home > Td5 > Injector seal replacement
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Got the injector seals replaced yesterday. I had noticed the oil level rising a wee bit but thought that could have been my imagination - it was running fine, not smoking and in general I thought it was good. Got all the bits including a new injector harness from Dan at Duckworth and sent the motor to my local indie - the boys used to work for our local Rover / LandRover / Jaguar dealer before they pulled out of town. On getting it back, I could tell the difference even before I started the engine. The fuel pump was almost inaudible instead of having a wee whine and sounding as if there was air in the system as before. Once running, the engine sounded a bit quieter and is pulling very well. As I said, I didn't think there was much wrong with it before, but there is a noticeable difference now that the work has been done.
I've only had the motor for 10k miles / 18 months so I don't know how long to expect it to last before needing done again, but I'd encourage anyone with the Td5 to get it done if you see or hear any of the symptoms - more pleasurable motoring awaits. As an aside, my mpg figures were down a bit - 22 mpg towing on the motorway last time instead of the 26/27 I have had in the past. Hopefully it will help bring this figure back up.
Post #577989 15th Nov 2016 8:08pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Been thinking about getting mine done, how many hours labour were you charged for the job??
Post #578008 15th Nov 2016 9:16pm
dorsetsmith
about 2 hr max id-say having had sum practice now x 2 Thumbs Up
Post #578017 15th Nov 2016 9:36pm
JWL
It's not that bad a job, last time I did mine was on a camp site at Bala, I think the only reason it took around the 2 hours was because all the rest of the camping party wanted to come over and see how it was done Rolling Eyes
Post #578042 15th Nov 2016 10:49pm
RoddyK05
Not sure how many hours it was, but it was £180 which included a change of oil too which he supplied. As mentioned, I supplied all the bits including both oil filters. Maybe this is over the odds, I don't know, but it is outside my skill level and he's the local Landy guy so he got the job.
Anyone have a rough idea how long this lasts before needing done again? What about the wiring harness, I've heard of people making it a service item and doing it annually?
Post #578046 15th Nov 2016 10:59pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Should last 100k Kms at least. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #578052 15th Nov 2016 11:20pm
JWL
Mine was done around 120K and soon after by me as the eejit that did it used the cheapest he could find then again last year which was just under 180K. It's on 192000 miles now with no issues. Thumbs Up
Post #578061 15th Nov 2016 11:48pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Roddy I see you are in Inverclyde, what was the local garage that you used as I am trying to find someone local to use
Keith
Post #578838 18th Nov 2016 10:18pm
RoddyK05
Keith,
I took it to my usual garage in Gourock and he took it up to the lad. I will find out what the other place is officially called and get their number.
Cheers, Roddy.
Post #578842 18th Nov 2016 10:37pm
lightning
I wanted to get the injector seals done on my TD5, but none of the local places wanted to do it, as it is running OK.
"You're opening a can of worms" said one, and "they might not re seal" plus "you might end up needing a new head"
The main dealer said l could end up with a bill for £3,000 and one of the lndys said they "didn't like to touch them"
I might do it myself. Is it easy to get the injectors out? The local lndy charges £50 to recover a broken Landy from a customer's drive!
Post #578896 19th Nov 2016 9:55am
dorsetsmith
this will good idea of how involved it is
http://www.discovery2.co.uk/Injector%20Seals.html
Post #578899 19th Nov 2016 10:19am
RoddyK05
Keith / drakes. The place is called 'The repair centre' and the number is 01475631618. The lad that done it is called Andy. Give him a call and he should be able to sort you out.
Post #579420 21st Nov 2016 2:11pm
srod
Why, if things are okay, do you want to get them done? Are these things guaranteed to fail at some point?
Post #579458 21st Nov 2016 4:32pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I sold my Td5 with nearly 250,000 miles on the clock. It had a three exhaust manifolds, a new turbo, was on its third intercooler, its fourth fuel pressure regulator and innumerable injector harnesses. But the injector seals were never touched and it ran just fine.
If it's running okay with no symptoms of anything untoward, my advice is to leave it well alone. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #579468 21st Nov 2016 5:22pm
4RF RDS
Totally agree wth that sentiment. The old adage of if it aint broke... seems to apply to most LR issues. Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #579591 22nd Nov 2016 1:31am
