![]() | Home > Maintenance & Modifications > Smooth Headlight Surround ? |
Your choices are to either have your headlight surrounds stripp either chemically or bead blasted OR find some unpainted surrounds. We have some unpainted Nakatanenga unpainted heritage light surrounds.
Brendan |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20910 ![]() ![]() |
Or key surrounds with 400 grit wet abc dry wet, plastic prime, hibuild primer, 600 grit dry sand, seal, 600 dry sand again with 600 dry paper.
Base coats, clear coats, if there is any peel you can flat with 2000 wet with a block and then cut down to a ultra fine compound to a polish. Probably not needed though, depends hw well you can lay the paint. Don't be scared of grille texture, you can easily overcome that. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
