Home > Maintenance & Modifications > Smooth Headlight Surround ?
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Hi Guys, can anyway point me in the right direction to a smooth headlight surrounds ?
I order a new headlight and grille package, the paint shop have painted the grille in Santorini which looks fantastic but won't paint the headlight panels as they are textured. It looks very odd now with just the grille painted, definitely want the headlight panels to match if I can track down a smooth one. Any help on my hunt appreciated!
Post #577215 11th Nov 2016 10:58pm
leeds
Your choices are to either have your headlight surrounds stripp either chemically or bead blasted OR find some unpainted surrounds. We have some unpainted Nakatanenga unpainted heritage light surrounds.
Brendan
Post #577219 11th Nov 2016 11:40pm
Or key surrounds with 400 grit wet abc dry wet, plastic prime, hibuild primer, 600 grit dry sand, seal, 600 dry sand again with 600 dry paper.
Base coats, clear coats, if there is any peel you can flat with 2000 wet with a block and then cut down to a ultra fine compound to a polish.
Probably not needed though, depends hw well you can lay the paint.
Don't be scared of grille texture, you can easily overcome that.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #577224 11th Nov 2016 11:59pm
