Home > Maintenance & Modifications > LR Def 110 electric winch
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
i have been reading multiple sites on winches and i think i am more confused than before. I am seeking a recovery winch (front mount) for the 97 110 station wagon. (dual batteries installed).
At this time i dont do much off-roading but i want the peace of mind that if push comes to shove i can winch myself outta trouble.
the car is mostly stock standard build (few extras as roll cage, larger rims/tyres and upgraded bumpers etc..) and i live in a tropical climate - so water is a constant as well as rubber /plastic breakdown and rust just from the elements (ant corrosion and water proof i guess is best)
from research i see around 4000-5700 lb is in the ball park ?
also looking for a low profile mount- given the temp and hill I dont want the restrict air flow to the radiator in any way if possible
experience and guidance approacuted
Post #575741 6th Nov 2016 4:52am
ericvv
5700 lbs is way too low, but I think you confuse lbs with kilos.
The standard Warn winch for the Defender (VPLDP0113) as offered by LR is for a capacity of 9500 lbs, or 4310 kilo. Some also install a 12.000 lbs winch.
There are others on here who are much bigger winch experts than me, so they may kick in.
One thing, as you say Singapore is a high humidity environment all year round, and those Warn winches are very prone to rusting over time as I see from those who have one here. You probably don't want a steel cable but a plasma rope there.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #575751 6th Nov 2016 8:53am
VeeTee
Netherlands
^ As Eric says, 9500 lbs is the standard capacity. I installed this Superwinch Talon 9500i last year, I do not have personal experience with Warn but what I see and hear from others is that they are overrated for their price. I choose plasma rope because it is safer and easier in use.
 Cheers, Vincent
MySite
Post #575766 6th Nov 2016 10:07am
itolond
Thanks all - the Superwinch - any guides on rusting etc?
Post #575795 6th Nov 2016 1:36pm
VeeTee
Netherlands
It's almost a year on now, still as new - but then I regular give it a coat of blank waxoyl and keep it under a neoprene cover. Cheers, Vincent
MySite
Post #575802 6th Nov 2016 1:55pm
Cupboard
www.defender2.net/forum/topic49371.html
Have a read of that thread, it's got lots of useful information.
Post #575816 6th Nov 2016 3:18pm
jst
a TDS from goodwinch, its waterproof for starters and can have uprated tie bars to avoid corrosion. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #575865 6th Nov 2016 6:30pm
