![]() | Home > Maintenance & Modifications > LR Def 110 electric winch |
5700 lbs is way too low, but I think you confuse lbs with kilos.
The standard Warn winch for the Defender (VPLDP0113) as offered by LR is for a capacity of 9500 lbs, or 4310 kilo. Some also install a 12.000 lbs winch. There are others on here who are much bigger winch experts than me, so they may kick in. One thing, as you say Singapore is a high humidity environment all year round, and those Warn winches are very prone to rusting over time as I see from those who have one here. You probably don't want a steel cable but a plasma rope there. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
^ As Eric says, 9500 lbs is the standard capacity. I installed this Superwinch Talon 9500i last year, I do not have personal experience with Warn but what I see and hear from others is that they are overrated for their price. I choose plasma rope because it is safer and easier in use.
![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 ![]() ![]() ![]() |
Thanks all - the Superwinch - any guides on rusting etc?
It's almost a year on now, still as new - but then I regular give it a coat of blank waxoyl and keep it under a neoprene cover. Cheers, Vincent
www.defender2.net/forum/topic49371.html
Have a read of that thread, it's got lots of useful information. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8326 ![]() ![]() ![]() |
a TDS from goodwinch, its waterproof for starters and can have uprated tie bars to avoid corrosion. Cheers
