Home > Technical > Lose crankshaft bolt with airgun
Bert@E
Netherlands
solved
Post #574154 29th Oct 2016 1:33pm
sako243
If you're referring to the pulley then all I can say is good luck Whistle (should be fine by the way).
I took out a 2.25 diesel and had to get the pulley off, our impact hammer didn't touch it. Scaffolding poles simply flipped the engine over on the bench. In the end a mate with an engine driven compressor in his van and a 1" drive managed to get it off but only just.
Bear in mind they're done up to approx 250ft lbs (note ft lbs not Nm!, that upwards of 350Nm I think) then you have x years off it to get seized...
I'd be curious to see if my new 1500Nm impact hammer could get one off.. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #574165 29th Oct 2016 3:17pm
sako243
One preferred method is a breaker bar and crank the engine over (if it runs) Whistle Ed
Post #574166 29th Oct 2016 3:17pm
Tiger
Thats how I did it Thumbs Up
Post #574168 29th Oct 2016 3:51pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've heard of people grinding the head off the bolt and then simply unscrewing the remains once the tension from the bolt on the pulley is off 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #574188 29th Oct 2016 4:59pm
Litch
Then again, lock the crankshaft with the correct tool and it might just come undone with a decent breaker bar (mine did). ONE LIFE, GET IT!
Post #574404 30th Oct 2016 6:53pm
mikeh501
Got the same task. My 18v rattle gun won't touch it. Need that special tool! Mines to fit a mega squirt timing wheel behind the pulley.
Post #574432 30th Oct 2016 8:30pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
That's the way I did my 200Tdi, lock the pulley against the chassis rail and a 2ft breaker bar with a 4ft scaffold pole extension Thumbs Up
Post #574637 31st Oct 2016 9:29pm
mikeh501
how did you lock the pulley against the chassis rail?
Post #574638 31st Oct 2016 9:31pm
jst
there is a special tool that pics up on the 4 crank pulley bolts. the arm of this rests against the chassis. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #574643 31st Oct 2016 10:07pm
Bert@E
Netherlands
Got the special tool for holding the pulley...
Tried with a facom breakerbar with a metal tube but the breaker bar bents...
Post #574987 2nd Nov 2016 6:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I just rest a breaker bar against the chassis and blip the starter, easy way to do it but if done wrong it can cause damage if done incorrectly, I have seen people just place the socket/breaker bar on the bolt at any angle and try and hold it Rolling with laughter
It quickly found a home on the chassis rail as they let go. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #574995 2nd Nov 2016 6:46pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
I changed the bottom pulley on my Td5 recently.
I made up a section on angle iron that would rest on the floor and used a long breaker bar with an extension tube to get the correct leverage.
All worked with no major issues.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #576165 8th Nov 2016 2:25am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I have one made up too, just the job. Wink
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #576197 8th Nov 2016 10:49am
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Nice work guys! Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #576350 8th Nov 2016 8:42pm
