![]() | Home > Technical > Lose crankshaft bolt with airgun |
Bert@E Member Since: 08 Jan 2016 Location: amsterdam Posts: 63 ![]() ![]() |
solved
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
One preferred method is a breaker bar and crank the engine over (if it runs)
![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Thats how I did it
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I've heard of people grinding the head off the bolt and then simply unscrewing the remains once the tension from the bolt on the pulley is off 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
Then again, lock the crankshaft with the correct tool and it might just come undone with a decent breaker bar (mine did). ONE LIFE, GET IT!
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Got the same task. My 18v rattle gun won't touch it. Need that special tool! Mines to fit a mega squirt timing wheel behind the pulley.
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
That's the way I did my 200Tdi, lock the pulley against the chassis rail and a 2ft breaker bar with a 4ft scaffold pole extension ![]() |
how did you lock the pulley against the chassis rail?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8401 ![]() ![]() ![]() |
there is a special tool that pics up on the 4 crank pulley bolts. the arm of this rests against the chassis. Cheers
Got the special tool for holding the pulley...
Tried with a facom breakerbar with a metal tube but the breaker bar bents... |
I just rest a breaker bar against the chassis and blip the starter, easy way to do it but if done wrong it can cause damage if done incorrectly, I have seen people just place the socket/breaker bar on the bolt at any angle and try and hold it
![]() It quickly found a home on the chassis rail as they let go. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 85 ![]() ![]() ![]() |
I changed the bottom pulley on my Td5 recently.
I made up a section on angle iron that would rest on the floor and used a long breaker bar with an extension tube to get the correct leverage. All worked with no major issues. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I have one made up too, just the job.
![]() ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Nice work guys!
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
