Home > Td5 > AS10 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2240 |
No.
29th Jun 2020 9:59pm |
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 |
If you want to be able to open the door with the key and stop the alarm going off you need to look for the key disarm in (I think) settings group 2 and change the setting.
29th Jun 2020 10:05pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
you need to make sure you have a genuine land rover CDL 4 wire motor to be able to do this.
Key disarm will do the job, but you need that part above to send that information. If you don't have the ultrasonic sensor, breaking the glass and pulling the lock up from the inside will do the same thing as key disarm. Might not be what you really want as the alarm won't sound. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
30th Jun 2020 3:55pm |
