Home > Puma (Tdci) > fuel filter water drain
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
If I was to loosen the drain from the fuel filter, to let 'water' out like it says on the service schedule - will air bubble up through the outlet and into the fuel system? must I pump diesel through at that special outlet under the bonnet?
Its been on there 18 months and I believe its about time I did it for the first time. 1953 80"
1987 mini city e
2011 90"
Post #568340 2nd Oct 2016 11:03pm
agentmulder
Kuwait
Reasonable logic but I believe the answer is no don't worry, go right ahead and do it. I've not had any issues and I do it every few months.
Tangentially on topic but I find the 'water' is quite oily, I didn't expect to drink it but I did wonder if it was just diesel coming out... Solved the bowel problem, working on the consonants...
Post #568345 3rd Oct 2016 1:20am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Don't worry about air entering the system, it's perfectly fine to drain, you only need to crack it a small amount before the water will drain. The U.K. Fuel is good so you shouldn't have too much water in there. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #568348 3rd Oct 2016 6:06am
