![]() | Home > Puma (Tdci) > fuel filter water drain |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Reasonable logic but I believe the answer is no don't worry, go right ahead and do it. I've not had any issues and I do it every few months.
Tangentially on topic but I find the 'water' is quite oily, I didn't expect to drink it but I did wonder if it was just diesel coming out... Solved the bowel problem, working on the consonants... |
Don't worry about air entering the system, it's perfectly fine to drain, you only need to crack it a small amount before the water will drain. The U.K. Fuel is good so you shouldn't have too much water in there. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
