Home > In Car Electronics > 2007 Defender 90 - ignition switch wiring diagram
2 GOS
Hi,
Does anyone have access to an ignition switch wiring diagram for a Puma - 2007?
Basically, which colour wire should switched items connected to?
Thanks in advance.
Post #561505 5th Sep 2016 9:16am
Rickydodah
Is this any help? I started with nothing and still have most of it left!
Post #561512 5th Sep 2016 9:51am
2 GOS
Wow. Huge thanks but do you have anything more simple?
I need to know what colour cable does what on the back of the switch.
Thanks again.
Post #561525 5th Sep 2016 11:08am
Martin
Site Admin
Brown/White - permanent 12V
Orange/White - Accessory (Position I) 12V to fuse box then to radio, lighter socket and heater fan
White - Ignition (Position II) 12V out to fuse boxes
Red/White - starter relay  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #561526 5th Sep 2016 11:14am
2 GOS
Many thanks Martin. Appreciated.
Sorry to be dense but do you know if it is reasonable to take use White - Ignition (Position II) as switched trigger - i.e DRLs on?
Thanks again. Very Happy
Post #561532 5th Sep 2016 11:34am
Martin
Site Admin
It would be fine, but it's a very large cable at the switch, so difficult to "tap" into reliably (particularly given the restricted space available).
I would personally use one of the white with green stripe cables (all of these are ignition switched) down near the steering column fuse box.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #561577 5th Sep 2016 2:19pm
2 GOS
Just the advice I needed. Thank you. Very Happy Very Happy
Post #561588 5th Sep 2016 3:07pm
