![]() | Home > In Car Electronics > 2007 Defender 90 - ignition switch wiring diagram |
2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66 ![]() ![]() |
Hi,
Does anyone have access to an ignition switch wiring diagram for a Puma - 2007? Basically, which colour wire should switched items connected to? Thanks in advance. |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
![]() Click image to enlarge Is this any help? I started with nothing and still have most of it left! |
Wow. Huge thanks but do you have anything more simple?
I need to know what colour cable does what on the back of the switch. Thanks again. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
Brown/White - permanent 12V
Orange/White - Accessory (Position I) 12V to fuse box then to radio, lighter socket and heater fan White - Ignition (Position II) 12V out to fuse boxes Red/White - starter relay ![]() ![]() |
Many thanks Martin. Appreciated.
Sorry to be dense but do you know if it is reasonable to take use White - Ignition (Position II) as switched trigger - i.e DRLs on? Thanks again. ![]() |
It would be fine, but it's a very large cable at the switch, so difficult to "tap" into reliably (particularly given the restricted space available).
I would personally use one of the white with green stripe cables (all of these are ignition switched) down near the steering column fuse box. ![]() ![]() |
Just the advice I needed. Thank you.
