Home > Tdi > 200/30tdi inter compatibility
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Hi guys, the 200 tdi defender engine in my 130 is tired, looking around my best bet for a Cost effective solution is a discovery engine from a donor disco. Now the 300 is far more plentiful, but will my defender turbo/ inlet/ exhaust gubbins fit on it to keep things kosher? I'm presuming on a 200 they definately are? I've had straight disco lumps in previous defenders and can't be doing with it all being 'not quite right'..
Many thanks in advance
Cheers. Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #559595 28th Aug 2016 8:16pm
ickle
I don't know about swapping bits 200 - 300 but I know the defender / disco manifolds are different, Defender being 'high turbo' the disco being low
I don't think many parts are interchangeable 200 - 300
Post #559599 28th Aug 2016 8:25pm
alwoodley72
Yes I want my defender high turbo on the disco lump, then I keep standard exhaust and am able to change a starter motor without dislocating my wrist...!
79 911 sc
Post #559633 28th Aug 2016 10:56pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Alex
I wouldn't worry too much about the starter motor, once you remove the induction pipe from the turbo you have more than enough access to get to it, I have hands best described as shovels and I can change a starter easily. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #559637 28th Aug 2016 11:13pm
alwoodley72
I cursed and swore last time mash, had to take exhaust off to get it out, plus I've got all the 'right' gear so would really like to go with that rather than a Steve Parker exhaust etc etc...
Cheers! Alex 98 300 tdi 90 project
79 911 sc
Post #559641 28th Aug 2016 11:28pm
Fatboy Slim
Wales
Swap your manifolds, timing case etc onto the disco lump. Done a few, not difficult. Much better than piddling around with s shaped downpipes and all that palaver . Depending on the age of your 200s you might have to swap the oil filter housings to keep your oil cooler pipe threads right but that's no biggy.
Defo wouldn't go down the 300 route
Post #560341 31st Aug 2016 9:03pm
alwoodley72
Thanks fs that's what I wanted to hear, anyone know of a rotten 200 tdi disco going cheap?!?...
Cheers alex 98 300 tdi 90 project
79 911 sc
Post #560363 31st Aug 2016 9:50pm
Fatboy Slim
Wales
Might be worth giving CWS a bell
Post #560376 31st Aug 2016 10:05pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Ebay has a few £200-£700
Post #560377 31st Aug 2016 10:06pm
