Home > Maintenance & Modifications > How do you remove....
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
The small black transfer lever?
Once the rubber gaiter is unhooked does it screw off? Pull off? Is there a clip somewhere?
Many thanks!
Post #559347 27th Aug 2016 5:18pm
agentmulder
Kuwait
There was a discussion on this topic updated not so long ago for the puma/TDCi, had pictures'n'all, try searching? Thumbs Up
If I recall it's a pull, but I'm not 100% on that! Solved the bowel problem, working on the consonants...
Post #559409 27th Aug 2016 10:42pm
mcma1
Pull, mind you don't knock your teeth out though.! Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #559464 28th Aug 2016 9:17am
Martyn
Aghh thought so. Will crank the pulling up a few notches as she won't budge.
Post #559481 28th Aug 2016 10:39am
K9F
http://www.defender2.net/forum/topic14602.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #559506 28th Aug 2016 11:55am
