Home > Technical > heated seats plugs
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
heated seats plugs
Does anyone know who manufacture the plug from heated seats and if they are available from anywhere?
Post #557319 19th Aug 2016 9:38pm
PaulMC on here IIRC can get them / has them.
Drop him a 'PM'.
Thumbs Up
Post #557321 19th Aug 2016 9:43pm
ginjez
Thanks Steve Bow down
Post #557328 19th Aug 2016 10:00pm
Welcome, hopefully Paul can sort you out. Thumbs Up
Post #557331 19th Aug 2016 10:06pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Just cut them off and fit waterproof 2 pin plugs off *bay less than £4 for 10
Post #557376 20th Aug 2016 9:14am
Yes, but with some kits you want it as factory as possible.
I did use Superseal on some connectors though, they do just the same job - arguably better you could say.
Post #557387 20th Aug 2016 10:31am
dgardel
Italy
The OM are the econoseal 2 way
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #557645 21st Aug 2016 11:25am
Martin
Site Admin
They aren't Econoseal on the heated seats, they are TE (aka AMP/Tyco) MQS connectors.
If Paul can't sort plugs (which go on the seats) I have some, but the sockets (which mount on the seat box) are trickier. I think Paul has got some though.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #557677 21st Aug 2016 2:18pm
PaulMc
The heated seat connectors are not Econoseal or Superseal, they're MQS connectors. Paul.
Post #557678 21st Aug 2016 2:20pm
Martin
Site Admin
Ner Ner Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #557679 21st Aug 2016 2:21pm
Cut and twist Thumbs Up
Post #557680 21st Aug 2016 2:32pm
dorsetsmith
OR LR052168 x 2
Post #557689 21st Aug 2016 3:17pm
PaulMc
Martin wrote:
Ner Ner Wink
Thank you Martin Wink
Shocked
The seats use MQS female connectors -
The male connectors are clipped to the seatbox -
Connector fitted with panel clip for the late TD5 and TDCi seatbox -
Connector fitted with panel clip for earlier seatboxes that require holes to be drilled -
Also - Lucas 25mm grommets -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #557692 21st Aug 2016 3:23pm
PaulMc
dorsetsmith wrote:
OR LR052168 x 2
These are supplied without terminals or wire seals.
. Paul.
Post #557696 21st Aug 2016 3:28pm
I had to use both for my set up, that's the only reason I mentioned Superseals.
The male and female, Tyco type connectors obviously have to be used together.
I had to use Superseal connectors additionally for mating a Genuine Loom to Waeco pad set.
This route you can either use the set up I did, or if at any time you wanted LR heated seats or similar they plug straight in.
Basically then you mimic a factory install.
Post #557697 21st Aug 2016 3:33pm
