![]() | Home > Technical > heated seats plugs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
PaulMC on here IIRC can get them / has them.
Drop him a 'PM'. ![]() |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1771 ![]() ![]() |
Thanks Steve
Welcome, hopefully Paul can sort you out.
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Just cut them off and fit waterproof 2 pin plugs off *bay less than £4 for 10
Yes, but with some kits you want it as factory as possible.
I did use Superseal on some connectors though, they do just the same job - arguably better you could say. |
The OM are the econoseal 2 way
![]() ![]() IID Pro MV License |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
They aren't Econoseal on the heated seats, they are TE (aka AMP/Tyco) MQS connectors.
If Paul can't sort plugs (which go on the seats) I have some, but the sockets (which mount on the seat box) are trickier. I think Paul has got some though. ![]() ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
The heated seat connectors are not Econoseal or Superseal, they're MQS connectors. Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Cut and twist
OR LR052168 x 2
Thank you Martin ![]() ![]()
![]() ![]() The seats use MQS female connectors - ![]() Click image to enlarge The male connectors are clipped to the seatbox - ![]() Click image to enlarge Connector fitted with panel clip for the late TD5 and TDCi seatbox - ![]() Click image to enlarge ![]() Click image to enlarge Connector fitted with panel clip for earlier seatboxes that require holes to be drilled - ![]() Click image to enlarge ![]() Click image to enlarge Also - Lucas 25mm grommets - ![]() . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
These are supplied without terminals or wire seals. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
I had to use both for my set up, that's the only reason I mentioned Superseals.
The male and female, Tyco type connectors obviously have to be used together. I had to use Superseal connectors additionally for mating a Genuine Loom to Waeco pad set. This route you can either use the set up I did, or if at any time you wanted LR heated seats or similar they plug straight in. Basically then you mimic a factory install. |
