![]() | Home > Puma (Tdci) > Serpentine belt change |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
What's the milage or time limit before the main serpentine belt on the 2.4 Puma is scheduled to be changed? I think it's some ridiculously high milage but I can't find the details. Thanks. 1982 88" 2.25 diesel
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Changed mine at 97000 miles for the same chirping noise, but mine did show tiny cracks in the vees. A lot of people say this is a good indicator of it needing to be changed. Still wouldn't leave it as long as 120000 though
That is what you call "Having faith in your component." Wish all the parts on the Defender had that expected level of performance and reliability
![]() Thanks ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
Mine was replaced at 72,000 miles on a 2008 truck. It was cracked and chirped a bit when cold. Tdci 110 DC
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Mines in good nick at 52k, at least I know how to change easily myself.
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
I'm sitting just over 85 000km with a slightly cracking belt and some chirping.
Been waiting 3 weeks for it to arrive in Maun! They only have 7PK2958 in stock. Have had to borrow an even older belt incase of emergency... Can someone please confirm that it is a 7PK3001 belt? 2012 2.2 Puma Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
PQS500610 is for vehicles without and PQS500600 for vehicles with aircondition.
Both numbers you mentioned are for vehicles with aircondition, insofar the same dimension. Btw, its easy to find out if you search the internet... ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
At 140k miles I think I had better have a look
Thanks hornet for those part numbers
![]() But that just caused more confusion on this side... The local LR still can't give me a part number ![]() I've been told that 7PK3001 means 7 is for the grooves in the pulleys & 3001 is the length in millimeters? Hence why the 2958 was just too short (I was concerned that the belt had stretched that much) ![]() Click image to enlarge Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
How much are they Genuine? Abd arm and a leg or just and arm or a leg?
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Mine was changed after 200,000 km. only for safety (was in good shape).
The second one last only 60,000 km but due other issues. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
2958 mm is the genuine length that turns out for PQS500600. I guess that a 3001 mm belt can be used with no problem because it's only ~13.7 mm in diameter difference which would be equalized through spanner. And yes, I could not find differences between 2.4 and 2.2 engines when consulting relevant sources like http://new.lrcat.com/#!/1235/3714/4215/330 In any case I would recommend to use a quality brand! Conti for example recommends 120.00km for a change (75.000 miles). HTH! |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
Is this job difficult to do? As anyone posted an idiots guide for this?
Edit. Sorry just found it. Stickied before. |
Maverick90 Member Since: 07 Jan 2017 Location: South Yorkshire Posts: 12 ![]() ![]() ![]() |
Where did you find this please? Is it necessary to change the pulleys?
