Home > Puma (Tdci) > Serpentine belt change
spudfan
Ireland
What's the milage or time limit before the main serpentine belt on the 2.4 Puma is scheduled to be changed? I think it's some ridiculously high milage but I can't find the details. Thanks. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #554698 9th Aug 2016 11:43am
hornet
120.000 miles/200.000 km (maintenance check sheet.)
Changed mine at 170.000 km because of chirping noise. But still looked good, no cracks.
Post #554728 9th Aug 2016 2:45pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Changed mine at 97000 miles for the same chirping noise, but mine did show tiny cracks in the vees. A lot of people say this is a good indicator of it needing to be changed. Still wouldn't leave it as long as 120000 though Shocked
Post #554732 9th Aug 2016 2:56pm
spudfan
Ireland
That is what you call "Having faith in your component." Wish all the parts on the Defender had that expected level of performance and reliability Whistle
Thanks Thumbs Up 1982 88" 2.25 diesel
Post #554815 9th Aug 2016 8:52pm
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
Mine was replaced at 72,000 miles on a 2008 truck. It was cracked and chirped a bit when cold. Tdci 110 DC
Post #554968 10th Aug 2016 11:34am
Mines in good nick at 52k, at least I know how to change easily myself.
Post #555000 10th Aug 2016 1:04pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I'm sitting just over 85 000km with a slightly cracking belt and some chirping.
Been waiting 3 weeks for it to arrive in Maun!
They only have 7PK2958 in stock.
Have had to borrow an even older belt incase of emergency...
Can someone please confirm that it is a 7PK3001 belt?
2012 2.2 Puma Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #555029 10th Aug 2016 1:51pm
hornet
PQS500610 is for vehicles without and PQS500600 for vehicles with aircondition.
Both numbers you mentioned are for vehicles with aircondition, insofar the same dimension.
Btw, its easy to find out if you search the internet... Thumbs Up
Post #555054 10th Aug 2016 3:05pm
smb
At 140k miles I think I had better have a look Whistle
Post #555074 10th Aug 2016 4:41pm
Bushpig
Thanks hornet for those part numbers Thumbs Up are these for the 2.2 2012 onwards?
But that just caused more confusion on this side...
The local LR still can't give me a part number Whistle
I've been told that 7PK3001 means
7 is for the grooves in the pulleys &
3001 is the length in millimeters?
Hence why the 2958 was just too short (I was concerned that the belt had stretched that much)
Douglas Adams
2012 2.2 Puma
Post #555089 10th Aug 2016 5:53pm
How much are they Genuine? Abd arm and a leg or just and arm or a leg? Whistle Rolling with laughter
Post #555090 10th Aug 2016 5:56pm
Eduardo
Mine was changed after 200,000 km. only for safety (was in good shape).
The second one last only 60,000 km but due other issues.
Cheers Eduardo
Post #555104 10th Aug 2016 7:13pm
hornet
2958 mm is the genuine length that turns out for PQS500600. I guess that a 3001 mm belt can be used with no problem because it's only ~13.7 mm in diameter difference which would be equalized through spanner. And yes, I could not find differences between 2.4 and 2.2 engines when consulting relevant sources like http://new.lrcat.com/#!/1235/3714/4215/330
In any case I would recommend to use a quality brand! Conti for example recommends 120.00km for a change (75.000 miles).
HTH!
Post #555224 11th Aug 2016 8:00am
Leviathan
Is this job difficult to do? As anyone posted an idiots guide for this?
Edit. Sorry just found it. Stickied before.
Post #555280 11th Aug 2016 12:04pm
Maverick90
United Kingdom 2007 Defender 90 Puma 2.4 SW Indus Silver
Where did you find this please? Is it necessary to change the pulleys?
Post #604171 23rd Feb 2017 2:02pm
