Home > Puma (Tdci) > Strange sick / smelly sock smell from heater/air con
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Hello,
I've done quite a bit of research into this but thought I would ask the question anyway in case anyone knows of a quick fix or exactly what it is...
I got into my 64 plate defender yesterday and no smell until I started her up and the heater fans came on... I was then hit with what can only be described as a manure / sick smell - although I believe it may be called sweaty sock syndrome Thud
Do any of you wise folk know what or how this has come about or how to fix it?
Michael
Post #554486 8th Aug 2016 3:18pm
VeeTee
Netherlands
If the vehicle has airco and if it has not been used for a long time, moulds and yeasts can grow in the aircon filter. Have the filter changed and use the airco once in a while, even if it is not hot. Cheers, Vincent
MySite
Post #554489 8th Aug 2016 3:31pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Check drain hole in air intake on wing for blockage. There may be all sorts of grunge in there, especially if you have been off road. If you have aircon or not used it for a while it could be a build up of bacteria in the system. You can buy an anti -bacterial spray to cleanse the system.
Post #554490 8th Aug 2016 3:32pm
LoveTheMud
fantastic, thank you both! Thumbs Up
Post #554491 8th Aug 2016 3:37pm
macfrank
Balvaig wrote:
There may be all sorts of grunge in there...
Indeed. A few weeks ago I noticed that smell in my MINI, and a rattle. This is what they found:
Mr. Green
Post #554532 8th Aug 2016 6:33pm
Romadog
Rolling with laughter
Post #554538 8th Aug 2016 7:14pm
LoveTheMud
Rolling with laughter Rolling with laughter Rolling with laughter
Post #554552 8th Aug 2016 8:29pm
HardCharger
Or, it could be your ignition switch burning up and fusing with one of the wires...
Post #554622 9th Aug 2016 3:59am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
If it is not debris then it is uncommon for air con to smell because of the bacteria crap while not being in uses. motor factors sell a spray that can clear the smell. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #554658 9th Aug 2016 8:53am
