![]() | Home > Puma (Tdci) > Strange sick / smelly sock smell from heater/air con |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Hello,
I've done quite a bit of research into this but thought I would ask the question anyway in case anyone knows of a quick fix or exactly what it is... I got into my 64 plate defender yesterday and no smell until I started her up and the heater fans came on... I was then hit with what can only be described as a manure / sick smell - although I believe it may be called sweaty sock syndrome ![]() Do any of you wise folk know what or how this has come about or how to fix it? Cheers Michael |
If the vehicle has airco and if it has not been used for a long time, moulds and yeasts can grow in the aircon filter. Have the filter changed and use the airco once in a while, even if it is not hot. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
fantastic, thank you both!
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1131 ![]() ![]() ![]() |
Indeed. A few weeks ago I noticed that smell in my MINI, and a rattle. This is what they found: ![]() Click image to enlarge ![]() |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 807 ![]() ![]() ![]() |
Or, it could be your ignition switch burning up and fusing with one of the wires...
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
If it is not debris then it is uncommon for air con to smell because of the bacteria crap while not being in uses. motor factors sell a spray that can clear the smell. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
