![]() | Home > Tdi > Am I missing something? |
Vesuvius Member Since: 06 Aug 2016 Location: Northumberland Posts: 17 ![]() ![]() |
First of all hello... already spotted some old friends from Kielder 4x4 and disco3 posting here...
Formalities out of the way... I'm hoping to answer a quick question if I may impose on everyone's weekend... Just got myself an old '94 300Tdi 130 that has been rebuilt just a few hundred miles ago... I've been underneath it for the first time trying to resolve a jumpy speedo. I noticed a suspicious looking bell housing - is it missing 4 bolts? If so anyone got a part number that might work for me? ![]() Click image to enlarge Thanks, J |
Try this one - not sure the last picture was immediately clear.
Yes you are, hope this helps:
![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Cheers Mash!
Are they LR part numbers? I'll have to get that sorted before it goes anywhere I guess! |
![]() Click image to enlarge also missing gear box wading plug to green arrow LR part number |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
IIRC when a Disco engine is mated to a Defender transmission, there are some bolts in the wrong place / not drilled and tapped ?
Is that what I have here? A disco engine and a defender box?
I don't know the full history of the vehicle but I think it is all defender. |
do you have drilled / threaded holes into the engine where the bolts are missing??
I've not looked in such detail...
I'll get back under it later. It all looks factory as the casting opposite each hole is shaped to be tapped. Will have a look and report back! |
Here is the other side.
Each of those ribs in the casting is opposite a bolt hole. ![]() Click image to enlarge |
Wrong image!
Try this ![]() Click image to enlarge |
m10 x 35 bolt flange head
CheersDS - that is perfect.
What is missing from the other two holes that are aligned centre? The look like they should be plugged with something? |
link to part numbers 300tdi engine and other defender part numbers
http://www.allbrit.de/UNI.cfm?PAGE=749047&SPRACHE=EN |
