Home > Tdi > Am I missing something?
Vesuvius
First of all hello... already spotted some old friends from Kielder 4x4 and disco3 posting here...
Formalities out of the way... I'm hoping to answer a quick question if I may impose on everyone's weekend...
Just got myself an old '94 300Tdi 130 that has been rebuilt just a few hundred miles ago... I've been underneath it for the first time trying to resolve a jumpy speedo. I noticed a suspicious looking bell housing - is it missing 4 bolts? If so anyone got a part number that might work for me?
Thanks,
J
Post #554097 6th Aug 2016 5:21pm
Vesuvius
wrong upload sorry!
Try this one - not sure the last picture was immediately clear.
Post #554098 6th Aug 2016 5:25pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Yes you are, hope this helps:
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #554102 6th Aug 2016 5:51pm
Vesuvius
Cheers Mash!
Are they LR part numbers?
I'll have to get that sorted before it goes anywhere I guess!
Post #554106 6th Aug 2016 6:38pm
dorsetsmith
also missing gear box wading plug to
green arrow LR part number
Post #554109 6th Aug 2016 7:07pm
ickle
IIRC when a Disco engine is mated to a Defender transmission, there are some bolts in the wrong place / not drilled and tapped ?
Post #554117 6th Aug 2016 7:53pm
Vesuvius
Is that what I have here? A disco engine and a defender box?
I don't know the full history of the vehicle but I think it is all defender.
Post #554118 6th Aug 2016 8:03pm
ickle
do you have drilled / threaded holes into the engine where the bolts are missing??
Post #554119 6th Aug 2016 8:07pm
Vesuvius
I've not looked in such detail...
I'll get back under it later.
It all looks factory as the casting opposite each hole is shaped to be tapped.
Will have a look and report back!
Post #554126 6th Aug 2016 8:51pm
Vesuvius
Here is the other side.
Each of those ribs in the casting is opposite a bolt hole.
Post #554128 6th Aug 2016 8:58pm
Vesuvius
Wrong image!
Try this
Post #554135 6th Aug 2016 9:08pm
dorsetsmith
m10 x 35 bolt flange head
Post #554143 6th Aug 2016 9:37pm
Vesuvius
CheersDS - that is perfect.
What is missing from the other two holes that are aligned centre?
The look like they should be plugged with something?
Post #554147 6th Aug 2016 9:48pm
mse
The central lower hole is a drain hole - you will find the same on the cambelt case
When off road/wade you should fit 2 blanking plugs in place. Mike
Post #554165 6th Aug 2016 11:27pm
dorsetsmith
link to part numbers 300tdi engine and other defender part numbers
http://www.allbrit.de/UNI.cfm?PAGE=749047&SPRACHE=EN
Post #554174 7th Aug 2016 6:53am
