Home > Puma (Tdci) > Strange sound at low speed...
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all... yet another "guess that sound" thread.
Since I've had my 110, it has always made a strange sound when toodling along in first or second gear, almost like a "rubbing" sound. It doesn't do it from the start, but if I keep on moving forward, with revs between 1k - 1.5K RPM it does it.
I generally hear it in traffic, as I'm moving along slowly. It is hard to describe, like a rubbing sound, but nothing is doing so.
You don't hear it in the higher gears or at higher speed.
Anyone else ever notice somthing like this?
Post #49386 22nd Dec 2010 4:02pm
MK
you mean from the Gbox-Tbox area? Puma 110" SW
Post #49391 22nd Dec 2010 4:39pm
eutek
No... from slightly forward from where I sit. At least to my ears! That would place it at the front diff?
The acoustics in the 110 do my head in.
Post #49639 24th Dec 2010 11:41am
Hilly
Hi did anyone ever get the bottom of this as I have a 110 2009 puma and have been experiencing the same weird rubbing noise at slow speeds. I thought originally it may have been a guard near the brake disc near side front but all seems to be well there and still have the noise seems worse when been driving it a while???
Thanks
Post #377105 7th Dec 2014 8:33pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Hey Hilly
Just had this with mine, it turned out to be a knackered UJ on the front propshaft.
Check your pads arent sticking aswell.
Good luck Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #377126 7th Dec 2014 9:46pm
Alicat
Had it with mine a couple of months back, it was the main shaft splines where they connect to the transfer box. A common problem.
Tony
Post #377145 7th Dec 2014 10:20pm
Hilly
Thanks all will get those things checked out.
Post #377213 8th Dec 2014 10:01am
