![]() | Home > Puma (Tdci) > Strange sound at low speed... |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
you mean from the Gbox-Tbox area? Puma 110" SW
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
No... from slightly forward from where I sit. At least to my ears! That would place it at the front diff?
The acoustics in the 110 do my head in. |
Hilly Member Since: 03 May 2014 Location: Cirencester Posts: 3 ![]() ![]() |
Hi did anyone ever get the bottom of this as I have a 110 2009 puma and have been experiencing the same weird rubbing noise at slow speeds. I thought originally it may have been a guard near the brake disc near side front but all seems to be well there and still have the noise seems worse when been driving it a while???
Thanks |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Hey Hilly
Just had this with mine, it turned out to be a knackered UJ on the front propshaft. Check your pads arent sticking aswell. Good luck ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 142 ![]() ![]() |
Had it with mine a couple of months back, it was the main shaft splines where they connect to the transfer box. A common problem.
Tony |
Thanks all will get those things checked out.
