Home > Puma (Tdci) > Cold weather rattle in front right of dashboard.
BigWheels
I had this last year, it went away until the temperature dropped this winter, & now its back again.
The rattle, coming from the front right corner of the dashboard, sounds like a wire, loose bit of plastic or connecting block is knocking against the inside of the moulding.
Has anyone any idea of what might be loose that needs taping down or re-fixing, if its come loose from somewhere?
No noise when the vehicle is standing still, but once moving, the knocking starts.
My XS is still under warranty at present. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #49316 22nd Dec 2010 12:33am
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
also have this really annoying issue! taking mine to dealers tommorow to shout at them!
james
Post #49443 22nd Dec 2010 8:12pm
TC
Obviously something not sorted cross variants as my 03 plate TD5 has started doing it!
Post #49471 22nd Dec 2010 10:09pm
spudfan
Ireland
Have a look at the rubbers on the bonnet hinges. They can wear allowing slight movement giving a noise like this. See if there is any movement in the bonnet.Mine needed rubber inserts. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #49472 22nd Dec 2010 10:09pm
fordy103
mines done 5000 miles from new so nothing should be worn in my opionion!!
Post #49530 23rd Dec 2010 12:01pm
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I've got a rattle too, but I've only done 2000 miles.
Mine sounds like a wire or loom rattling when going over bumps (so all the time).
When the weather warms up above freezing I was going to try and have look. Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #49533 23rd Dec 2010 12:15pm
BigWheels
Doesn't sound metallic in any way, & unless its stethoscoping, sounds like happening inside the vehicle. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #49560 23rd Dec 2010 5:45pm
