![]() | Home > Puma (Tdci) > rear lamp cover gone |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6689 ![]() ![]() ![]() |
LR010619 I think, although there's no photo online to confirm.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
Great, thanks. I'll give it a try.
How did you find that part anyway? |
http://new.lrcat.com/ and http://cat.lrparts.ru
The washer is EYF500050 and the screw AR610052 However given how dirty and corroded these screws get I would be tempted to replace with stainless. AR610052 can be replaced with a 4.8mm x 16mm self tapping screw (#10 x 5/8") Edit: EYF500050 is a large diameter M5 washer ![]() ![]() |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
I replaced my Self Tapping Screws with Hex Head Stainless ones, therefore much easier to tighten and undo, the Pozi Head only fills up with c**p. something like this - http://www.westfieldfasteners.co.uk/A2_Tap..._No.8.html NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Hex head replacement is a good call
Ask me how I know NormanD WE191
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
OP - Have you considered the Gwyn Lewis mud shields instead. They also protect the rear cross member.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20923 ![]() ![]() |
I'm sure Martin has this one correct but if you go to buy you could always check with Dan @ Duckworth parts too.
He can give you prices as well. You might already be sorted though, but just a suggestion. ![]() |
Thanks for reminding me. I'll have a look again. |
I'd love to. Sadly p&p costs from the UK to Europe are rather expensive in general, so it's cheaper for me to order at a Germany-based wholesale dealer. |
They are only a bit of plastic, it would be easy enough to cut a replacement out of sheet material. Steve.
