![]() | Home > Puma (Tdci) > rear lamp cover gone |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
LR010619 I think, although there's no photo online to confirm.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
Great, thanks. I'll give it a try.
How did you find that part anyway? |
http://new.lrcat.com/ and http://cat.lrparts.ru
The washer is EYF500050 and the screw AR610052 However given how dirty and corroded these screws get I would be tempted to replace with stainless. AR610052 can be replaced with a 4.8mm x 16mm self tapping screw (#10 x 5/8") Edit: EYF500050 is a large diameter M5 washer 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291
I replaced my Self Tapping Screws with Hex Head Stainless ones, therefore much easier to tighten and undo, the Pozi Head only fills up with c**p. something like this - http://www.westfieldfasteners.co.uk/A2_Tap..._No.8.html NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Hex head replacement is a good call
2015 D90 XS SW |
Ask me how I know NormanD WE191
| driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111
OP - Have you considered the Gwyn Lewis mud shields instead. They also protect the rear cross member.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
I'm sure Martin has this one correct but if you go to buy you could always check with Dan @ Duckworth parts too.
He can give you prices as well. You might already be sorted though, but just a suggestion. |
Thanks for reminding me. I'll have a look again. |
I'd love to. Sadly p&p costs from the UK to Europe are rather expensive in general, so it's cheaper for me to order at a Germany-based wholesale dealer. |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
They are only a bit of plastic, it would be easy enough to cut a replacement out of sheet material. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
