![]() | Home > For Sale & Wanted > [Wanted] Defender XS Drivers seat |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
Exmoor trim will probably do a matching retrim kit with new foam. If it is only the base it would take max 30mins to strip and replace.
HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131 ![]() ![]() |
have a look at oemlandrovers kits as well. 2002MY Defender 90 H/T
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I think they're a bit prone to the seat foam collapsing like that, seat bases too, I've had two 90s that had both gone the same way with the metal frame on the back coming right through the foam.
I used an Exmoor trim replacement foam section both times, the newer ones are better now with a reinforcing bit where the frame goes, it can be a bit fiddly but not too bad, there's quite a good video tutorial on their site too. ![]() |
tomm Member Since: 10 Mar 2016 Location: london Posts: 25 ![]() ![]() ![]() |
Brilliant, thanks all -will give them a go.
