Home > For Sale & Wanted > [Wanted] Defender XS Drivers seat
tomm
United Kingdom 2012 Defender 110 Puma 2.2 USW Zermatt Silver
The previous owner was either a big fatty or drove gangster style on a massive leftward lean. The top section of the driver seat has lost all its left side support so looking to replace that.
Cheers,
tom
Post #546537 6th Jul 2016 2:10pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Exmoor trim will probably do a matching retrim kit with new foam. If it is only the base it would take max 30mins to strip and replace.
Post #546547 6th Jul 2016 2:55pm
HossBog
have a look at oemlandrovers kits as well. 2002MY Defender 90 H/T
Post #546576 6th Jul 2016 4:59pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I think they're a bit prone to the seat foam collapsing like that, seat bases too, I've had two 90s that had both gone the same way with the metal frame on the back coming right through the foam.
I used an Exmoor trim replacement foam section both times, the newer ones are better now with a reinforcing bit where the frame goes, it can be a bit fiddly but not too bad, there's quite a good video tutorial on their site too. Thumbs Up
Post #546593 6th Jul 2016 6:30pm
tomm
Brilliant, thanks all -will give them a go.
Post #546890 7th Jul 2016 5:40pm
