Home > Puma (Tdci) > MT82 output shaft early symptoms
Hal
Can anyone say whether the following are early symptoms of mt82 output shaft failure: every few hundred miles in the last 1000 I get a short 1 to 2 seconds of screech that sounds to me like splines failing. I can feel loss of drive. Trouble is I'm fairly deaf (I wear hearing aids) so figuring out what the sound is and where exactly it comes from is a bit difficult (on the plus side I don't care how noisy my deafender is!). It does come from the front, either axle or perhaps transmission tunnel. I've had the drive flanges off and the splines look like brand new (2011 puma 110sw with 31k miles), which is a shame as that would've been easy to fix.
So, does this match with what others have seen before output shaft failure?
Thanks
Post #545429 2nd Jul 2016 8:42pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
When mine failed the only warning I had was a heavy metallic clunk noise when engaging gears or pulling away which only lasted a very short time before total loss of drive.
Post #545450 2nd Jul 2016 9:30pm
Hal
Thanks for reply.
I've got two choices I think:
1. Leave it til something breaks proper
2. Take bits apart til I find the problem. My guesses are in order of easiest to hardest - half shaft into diff, diff, output shaft, xfer box, clutch (broken springs getting stuck), gearbox.
Second option starts to get expensive (have to buy spares, seals, gaskets, tools) and takes a lot of time (months as also got to replace 100m of fence panels, build chicken enclosure to keep out foxes - electric fence may be needed) and got to keep wife happy.
First option could turn out expensive (but everything can be fixed at a cost).
Anyone able to make any suggestions?
Thx
Post #545462 2nd Jul 2016 9:55pm
DAZ110
My clutch plate springs were loose and made a spreeching noise every now and then. It then slowly got harder to engage gear until I had to have a new clutch fitted.
Post #545470 2nd Jul 2016 10:13pm
Pickles
Exactly,....that is what happened to us,..so really, there is no useful timeworthy notice at all,...it just "goes"!
So, whatever the O.P. is experiencing,..it ain't the input shaft.
Pickles.
Post #545472 2nd Jul 2016 10:14pm
A "screech" sound makes me think clutch (spigot bearing or release bearing) not imminent spline failure. It is unlikely with spline failure that you lose drive and then regain it, once lost it stays lost.
Another alternative might be a split intercooler pipe which will screech and cause a big loss of power, possibly enough to feel like a loss of drive.
Post #545475 2nd Jul 2016 10:16pm
Hal
Gents, thanks very much. I'll check out hoses just in case. Clutch symptoms seem reasonable to me, I'll keep an eye on that - I hasd thought clutch feel had changed recently.
Post #545524 3rd Jul 2016 7:27am
jst
^^^^ seems more likely to me Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #545547 3rd Jul 2016 8:45am
Jano300783
Spain
Well this week I downloaded the transfer to repair it and when you remove it you see the output shaft that comes from the gearbox. The case is that the striation is quite worn and wanted to change it, but there is no way to loosen the screw. So I am giving Sticks of blind since I do not know if it looses right or left.
Has anyone ever taken it apart?
Post #643606 13th Aug 2017 12:47pm
