![]() | Home > Puma (Tdci) > MT82 output shaft early symptoms |
| Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310
When mine failed the only warning I had was a heavy metallic clunk noise when engaging gears or pulling away which only lasted a very short time before total loss of drive.
| Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91
Thanks for reply.
I've got two choices I think: 1. Leave it til something breaks proper 2. Take bits apart til I find the problem. My guesses are in order of easiest to hardest - half shaft into diff, diff, output shaft, xfer box, clutch (broken springs getting stuck), gearbox. Second option starts to get expensive (have to buy spares, seals, gaskets, tools) and takes a lot of time (months as also got to replace 100m of fence panels, build chicken enclosure to keep out foxes - electric fence may be needed) and got to keep wife happy. First option could turn out expensive (but everything can be fixed at a cost). Anyone able to make any suggestions? Thx |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
My clutch plate springs were loose and made a spreeching noise every now and then. It then slowly got harder to engage gear until I had to have a new clutch fitted.
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802
Exactly,....that is what happened to us,..so really, there is no useful timeworthy notice at all,...it just "goes"! So, whatever the O.P. is experiencing,..it ain't the input shaft. Pickles. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
A "screech" sound makes me think clutch (spigot bearing or release bearing) not imminent spline failure. It is unlikely with spline failure that you lose drive and then regain it, once lost it stays lost.
Another alternative might be a split intercooler pipe which will screech and cause a big loss of power, possibly enough to feel like a loss of drive. |
Gents, thanks very much. I'll check out hoses just in case. Clutch symptoms seem reasonable to me, I'll keep an eye on that - I hasd thought clutch feel had changed recently.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
^^^^ seems more likely to me Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Jano300783 Member Since: 12 Aug 2017 Location: Zarzalejo Posts: 3
Well this week I downloaded the transfer to repair it and when you remove it you see the output shaft that comes from the gearbox. The case is that the striation is quite worn and wanted to change it, but there is no way to loosen the screw. So I am giving Sticks of blind since I do not know if it looses right or left.
Has anyone ever taken it apart? |
