![]() | Home > Td5 > TD5 Rocker Gasket - Any other jobs at the same time |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
I did the injector loom because I had to. May be worthwhile, and simple to do. I had oil in ECU red plug. Possibly a waste of money, maybe not?
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2284 ![]() ![]() ![]() |
Yep, +1 for the injector loom with the mk1collector sealing mod
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
Thanks for all the quick responses gents
![]() Do I bother with injector washers and O-rings or is that tempting fate? Harry |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
I normally do injector seals at 60-70K as a preventative measure. For the sake of an hours work it's worth doing. I change the injector hold down bolts and rocker shaft bolts as well.
Ta da!
http://www.defender2.net/forum/topic37090....ector+loom All you need to know about sealing said loom, courtesy of Ray ![]() I never considered the injector seals. Something for me to do over summer methinks. ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 988 ![]() ![]() ![]() |
The half round black rubber seal for the cam (located at the front of the engine). Often leaks with age. Change that out too. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
The only td5 that doesn't leak oil is the one with no oil in it - Wise old Chinese proverb.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
The cam cover /bung seal tend to be the real culprit for leaks.
Thanks for the advice guys, most appreciated, will definitely seal the loom as per MK1collector's mod before fitting it.
Could anyone advise on an appropriate type of sealant to use? I was looking at Sikaflex 512 which is not conductive but there is no info as to whether it's oil resistant. I was planning to use RTV for the 1/2 moon on the rocker gasket and the cam seal. For reference part no's are below: Rocker gasket - ERR7094 Injector loom - AMR6103 Injector washers - ERR6147 Injector o-rings - ERR7004 Front cam seal - LDI100030 Injector hold down bolts - MBD100050 Rocker shaft bolts - FS106307L Thanks, Harry |
