![]() | Home > Puma (Tdci) > Gearbox sensor? Aft of the bleed, just before the TrnsfrBox |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17899 ![]() ![]() ![]() |
It sounds to me as though you're describing the reversing light switch.
There are no sensors as such anywhere on the transmission. There are however the reversing light switch (on the upper n/s of the main gearbox), and two switches on the o/s upper front of the transfer box (high/low range and difflock wraning lights). There are some points where various harnesses are secured to clips etc. as well. Does it look like this? ![]() Click image to enlarge |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
OK, I'll unplug it.
I got a new clutch at 100000km, suspect mech didn't put to much care into reinstalling the cable harnesses to the correct spots. The cables for this switch are under an unhappy tension. Solved the bowel problem, working on the consonants... |
I was underneath, but yeah it does look familiar. I didn't realise it was so close to the lever, that quite often happens between top side and down.
"Wahhht!?! I'm here ?? ohhhhh" Solved the bowel problem, working on the consonants... |
