![]() | Home > Td5 > diesel fuel filter replacement questions |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 988 ![]() ![]() ![]() |
Probably dirt in the plug's clip on. Spray some cleaner or blast it with compressed air then try the push in pull apart thing.
Fot the 04 are you sure you have the correct filter? The Tdi filter looks exactly the same but has a smaller screw in on the bottom. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
o.k. will try the cleaner tonight. Effie the 2004 TD5 is definitely a TD5
![]() Minor annoying thing now is that when I try and lock the fuel guard over the filter, the silly little clip that it locks into has disintegrated so I need anther one Sigh! at least its small stuff. A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
You could just drill a hole below the spring tab thingy and put a small bolt with a wing nut on it until you can source a new part??? driving without the shield for any length of time is not the best idea but you might to be okay on dry pavement. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
Think I'll have to do some drilling. You need to purchase WKT100010 which is the back plate of the filter cover ..... you can't buy the clip by itself. The cover is ~£14 + VAT!!
Ill cobble something together Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3347 ![]() ![]() |
JUST in case you don't know...l am sure you will.
Fill the new filter with diesel if possible before you fit it. Then turn on the ignition (don't start it) and quickly press the gas pedal to the floor five times, starting the process before the ECU light goes out. This puts the fuel system into purge mode and you will hear the fuel pump running/stopping. There will be a red light flashing on the dash. Leave it until the red light stops flashing (about five minutes) Then turn off the ignition. After that just drive as normal. |
