Home > Td5 > diesel fuel filter replacement questions
alexatnd
Hi
Got a couple of questions
On my 1999 TD5 110 the drain valve has a couple of wires coming out of it to a plug and socket affair.I'm assuming this is for the water sensor.How do I get them apart? is is just a case of a screwdriver between the join? There is a push in clip but pushing in and trying to pull apart doesn't do much.
On my 2004 TD5 110 there aren't any cables just a screw in drain tap. I've removed and cleaned that but next problem is that the tap doesn't fit into the bottom of the new filter. The threaded end isn't the same diameter as the hole in bottom of the diesel filter. Does the drain tap screw into another bit that screws into the filter? Don't think this filter has been changed in god knows how long.
Rgds
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #537677 5th Jun 2016 12:12pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Probably dirt in the plug's clip on. Spray some cleaner or blast it with compressed air then try the push in pull apart thing.
Fot the 04 are you sure you have the correct filter? The Tdi filter looks exactly the same but has a smaller screw in on the bottom. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #537894 6th Jun 2016 12:51pm
alexatnd
o.k. will try the cleaner tonight. Effie the 2004 TD5 is definitely a TD5 Smile) The local land rover parts distributor checked the TD5 drain plug fitted the flavour of fuel filter they sell ( 1 box=air,oil and diesel filters). Manged to get the old one off last night. god knows ho long its been on there, was full of crap and rusted to hell, even round the rubber seal at the top. As you suggested perhaps the filter that was on it came from a non TD5.
Minor annoying thing now is that when I try and lock the fuel guard over the filter, the silly little clip that it locks into has disintegrated so I need anther one Sigh! at least its small stuff.
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #538461 8th Jun 2016 10:02am
4RF RDS
You could just drill a hole below the spring tab thingy and put a small bolt with a wing nut on it until you can source a new part??? driving without the shield for any length of time is not the best idea but you might to be okay on dry pavement. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #538480 8th Jun 2016 11:16am
alexatnd
Think I'll have to do some drilling. You need to purchase WKT100010 which is the back plate of the filter cover ..... you can't buy the clip by itself. The cover is ~£14 + VAT!!
Ill cobble something together Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #538485 8th Jun 2016 12:06pm
4RF RDS
1967 MGB GT
Post #538488 8th Jun 2016 12:21pm
lightning
JUST in case you don't know...l am sure you will.
Fill the new filter with diesel if possible before you fit it.
Then turn on the ignition (don't start it) and quickly press the gas pedal to the floor five times, starting the process before the ECU light goes out.
This puts the fuel system into purge mode and you will hear the fuel pump running/stopping. There will be a red light flashing on the dash. Leave it until the red light stops flashing (about five minutes) Then turn off the ignition.
After that just drive as normal.
Post #538815 9th Jun 2016 12:43pm
