![]() | Home > Wheels & Tyres > Wheel nuts - 1-1/16 ?? |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I thought they were just 27mm
They are 27mm wheel nuts I beleve so your 27mm socket was correct begin with! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
Odd....
The 27mm socket is even bigger than the 1-1/16 It's fine when using hand tools but when using the impact gun I'd like a tighter fit ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5140 ![]() ![]() ![]() |
27 mm to inches is 1.06299 and converting into a fraction does not quite work out as 1-1/16 this is an approximation and the figure assumed after rounding.
(1) Subtract 1, the number of whole inches. 1.06299 - 1 = .06299 (2) Multiply .06299 x 16 to get the number of 16th's inches remaining. .06299 x 16 = 1.00784 1.00784 = the number of 16th's of an inch. This is the numerator of the fraction. Apply the rules for rounding 1.00784 rounds to 1 because .00784 is less than .5 Therefore, 1.06299in. =(approximately) 1 and 1/16ths inch The nearest you could get to 27mm to an almost exact fraction of an inch if such was available would be a socket where the tolerance was worked in 100000 of an inch this would give you a size 1 and 6299.00000000001/100000ths inch(es) which is just .1 100000 of an inch short . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
all this help on bank holiday and fraction
Hmms... Thank you gilarion for the explanation. So I've bought a socket the exact same size as the 27mm socket. Balls!
But what size an I supposed to use though? 27mm seems a bit too big. It's fine on hand tools but my impact driver is making ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
27mm is correct. Has someone removed the stainless caps off yours? makes them around 26mm.
Mike |
