Home > Wheels & Tyres > Wheel nuts - 1-1/16 ??
dantastic
After having been using a 27mm socket for years I wanted to do the 'right thing' with my new 90 and ordered a 1-1/16 impact socket.
But I think it's a bit loose on the wheel nuts - what gives???
(Standard LR alloy wheel nuts)
Before someone mentions it, the socket is a Gedore socket so pretty high quality. Haven't measured it but I don't expect it to be off.
Are the alloy nuts not 1-1/16? Or what are they??
Post #535843 30th May 2016 1:41pm
Roy5695
I thought they were just 27mm Confused
Post #535846 30th May 2016 1:51pm
shaggydog
They are 27mm wheel nuts I beleve so your 27mm socket was correct begin with! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #535847 30th May 2016 1:53pm
dantastic
Odd....
The 27mm socket is even bigger than the 1-1/16
It's fine when using hand tools but when using the impact gun I'd like a tighter fit Confused
Post #535880 30th May 2016 3:51pm
gilarion
27 mm to inches is 1.06299 and converting into a fraction does not quite work out as 1-1/16 this is an approximation and the figure assumed after rounding.
(1) Subtract 1, the number of whole inches.
1.06299 - 1 = .06299
(2) Multiply .06299 x 16 to get the number of 16th's inches remaining.
.06299 x 16 = 1.00784
1.00784 = the number of 16th's of an inch. This is the numerator of the fraction. Apply the rules for rounding
1.00784 rounds to 1 because .00784 is less than .5
Therefore, 1.06299in. =(approximately) 1 and 1/16ths inch
The nearest you could get to 27mm to an almost exact fraction of an inch if such was available would be a socket where the tolerance was worked in 100000 of an inch this would give you a size 1 and 6299.00000000001/100000ths inch(es) which is just .1 100000 of an inch short . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #535883 30th May 2016 4:15pm
dorsetsmith
all this help on bank holiday and fraction Bow down Bow down
Post #535890 30th May 2016 4:41pm
dantastic
Hmms... Thank you gilarion for the explanation. So I've bought a socket the exact same size as the 27mm socket. Balls!
But what size an I supposed to use though? 27mm seems a bit too big. It's fine on hand tools but my impact driver is making Censored of the nuts because of the play.
Post #536786 2nd Jun 2016 9:21am
miker
27mm is correct. Has someone removed the stainless caps off yours? makes them around 26mm.
Mike
Post #536824 2nd Jun 2016 10:31am
