Home > Technical > Anyone know what this is?
The Hulk
Scotland 1997 Defender 110 300 Tdi HT Aintree Green
There's a second cable on my throttle mechanism which is currently very slack. It's connected to a half-moon-shaped lever (which is also very loose). This lever pushes the throttle mechanism in the same way as the accelerator cable pulls it.
[For some reason the photo is turning 90 degrees when I upload it so you'll have to turn your head to see it properly - it's the black and rusty bit at the bottom of the photo, or on the right of the photo if you look at it landscape]
The cable heads down to a cylinder approx 2" diameter attached to the chassis. The cylinder has a screw at base of it which shows over an inch of thread exposed.
Does anyone have any idea what this is? The 90 doesn't have this additional cable but is otherwise identical. Mid Life; Live It!
Ongoing thread: http://www.defender2.net/forum/topic45697.html
110 300Tdi Utility (Hulk)
90 300Tdi SW (GF's Tank)
Post #535781 30th May 2016 8:45am
LR90XS2011
is it some sort of damper arrangement to smooth throttle inputs and make it a smoother drive DEFENDER 90 TDCI XS,
Post #535782 30th May 2016 8:57am
Pilgrimmick
Looks like some sort of home made hand throttle arrangement. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #535784 30th May 2016 9:00am
The Hulk
I did wonder about some kind of hand throttle / cruise control but the location of the cylinder is very low down on the inside edge of the chassis.
Could it be something to do with the PTO winch? I can't see anything going from the cylinder to anywhere else but I need to get a good look at it and take a photo... Mid Life; Live It!
Post #535796 30th May 2016 10:07am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
The left hand cable is the normal throttle pedal cable and the right hand cable is a hand throttle, it works by pulling the outer metal part against the throttle pedal mechanism.
It can be added or removed easily, this is the same method that all the Wolf FFRs use to keep a high idle whilst being static. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #535800 30th May 2016 10:21am
The Hulk
Yep, it definitely seems to be a secondary (hand) throttle, but it is activated by a control which is integrated with the PTO winch hydraulics so there's no 'hand' throttle in the cabin. Mid Life; Live It!
Post #536063 31st May 2016 11:31am
shaggydog
I think your correct in that it is a hand throttle but it may be linked directly to the pto Unit so that when engaged it automatically sets the revs correctly to match the pto rather than rely on the operator to try and find what they think is the correct range.
The tube may be almost like a governor so that as the hydraulics take load the engine revs can be slightly increased to compensate.
Like everything else connected to it i think if its not causing any issues it is probably best left alone. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #536079 31st May 2016 1:27pm
