Home > Puma (Tdci) > Puma 110 Rear Carpet Pieces
yorkshireman
Hi, can anyone suggest where I can get individual pieces of carpet for the rear of my 110. I only actually need the piece that fixes to the body panel under the rear side windows. Either separates or the carpet on a roll would be great so I can make up my own. Tried Exmoor but they only sell the full set.
Post #533007 19th May 2016 7:51pm
LRI-Solutions
Do you have a TDCI? Is it this bit you are after?
 LRI Solutions Ltd
www.lrisolutions.co.uk
Post #533035 19th May 2016 8:48pm
yorkshireman
Yep that's the bit, need each side.
Post #533049 19th May 2016 9:12pm
LRI-Solutions
PM sent LRI Solutions Ltd
Post #533051 19th May 2016 9:15pm
AndyS
Do you get odds and sods of carpet? I need a bit about 95 cm x 25 cm (I'll measure it properly if you have a bit) to fill this bit...
Post #533266 20th May 2016 8:06pm
excossack
I got some black carpet from http://www.martrim.co.uk/catalogue/carpet-sheets.html at one of the shows 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #533267 20th May 2016 8:20pm
AndyS
Thanks, excossack, that looks like it'll hit the spot exactly. I'll get some ordered. Thumbs Up
Post #533539 21st May 2016 9:43pm
yorkshireman
Thanks for your help Steve, great to deal with. Thumbs Up
Post #533989 23rd May 2016 3:38pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
AndyS - Don't suppose you could send me a link where to get a similar black matting to you have on top of your drawer?
Post #534272 24th May 2016 1:00pm
AndyS
Yeah, sure...
http://www.ebay.co.uk/itm/331032963389
It's up for £28 at the moment (for a 6' x 4', 10mm thick bit of foam-type rubber) but I paid £22.40 so maybe they have sporadic discounts on it. There are many other options including a chequer plate design...
I wanted to check it out with the cheapest I could find before paying out anything more than I had to. It's very easy to cut with a Stanley knife so easy to adjust if needed.
Post #534346 24th May 2016 8:42pm
Scotm
Thanks - will give that a try.
Post #534454 25th May 2016 9:06am
