![]() | Home > Puma (Tdci) > Puma 110 Rear Carpet Pieces |
LRI-Solutions Member Since: 27 Feb 2014 Location: Rye Posts: 144 ![]() ![]() |
Do you have a TDCI? Is it this bit you are after?
![]() Click image to enlarge LRI Solutions Ltd ![]() www.lrisolutions.co.uk |
yorkshireman Member Since: 28 Mar 2016 Location: North England Posts: 80 ![]() |
Yep that's the bit, need each side.
PM sent LRI Solutions Ltd
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
Do you get odds and sods of carpet? I need a bit about 95 cm x 25 cm (I'll measure it properly if you have a bit) to fill this bit...
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5976 ![]() ![]() ![]() |
I got some black carpet from http://www.martrim.co.uk/catalogue/carpet-sheets.html at one of the shows 1999 Defender TD5 110
Thanks, excossack, that looks like it'll hit the spot exactly. I'll get some ordered.
Thanks for your help Steve, great to deal with.
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
AndyS - Don't suppose you could send me a link where to get a similar black matting to you have on top of your drawer?
Yeah, sure...
http://www.ebay.co.uk/itm/331032963389 It's up for �28 at the moment (for a 6' x 4', 10mm thick bit of foam-type rubber) but I paid �22.40 so maybe they have sporadic discounts on it. There are many other options including a chequer plate design... ![]() I wanted to check it out with the cheapest I could find before paying out anything more than I had to. It's very easy to cut with a Stanley knife so easy to adjust if needed. |
Thanks - will give that a try.
