Home > Td5 > Another one from me sorry
yanto
Wales
My 2003 td5 sounds very rattly? But when I accelerate it goes away and sounds lovely. It's not the transmission. I know td5's are noisy but this seems to be a wee bit too much. Seems a tad better when warm. I was thinking of putting it in for a health check at a dealer or indi. It's only done 69000 miles with full history.
Thanks.
Post #532782 18th May 2016 9:21pm
shaggydog
What sort of rattely?
Like tin heat shield loose underneeth or engine tappety rattely or interior trim clip loose rattely just to suggest a few?
Dont worry about lots of questions, thats what helps build knowlage! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #532785 18th May 2016 9:31pm
Lancerdoc999
where does it sound like its coming from?
I have a 2000 TD5 CSW so can compare. I live west of Cardiff.
Post #532798 18th May 2016 10:05pm
yanto
Wales
Definitely from the engine. Almost like a heavy diesel knock.
Ian.
Post #532874 19th May 2016 8:58am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
My td5 does the same on light throttle openings when cold. Diesel clatter. It disappears when you accelerate and goes away almost completely after a couple of miles.
I don't know if it's a sign of a problem or not, but it's always been like it and I've had for 4 years.
It had a service at a local Land Rover specialist and the never mentioned it.
I just assumed they all did it.
My wife's freelander 2 does it too, but it's much better soundproofed so you hardly notice it. 2002 td5 90 county hardtop
Post #532884 19th May 2016 10:02am
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
Mine (new to me, 76,000) makes a fair racket, sounds a bit tappety/clattery but to be honest I put it down to Land Rover Defender Td5 Engine Syndrome...
I've nothing to compare it to but whilst I'm over sensitive to any noise, like the current low whine (is that the drive shaft/gearbox/diffs/...) I think I can over analyse these things...
So... Current clattery noise is just normal until someone tells me different Smile
I suspect our two vehicles are making the same (normal) noise...
Post #532946 19th May 2016 2:46pm
yanto
Wales
That would be good. Where about are you? You can have a drive of mine and see how it goes.
Ian
Post #532979 19th May 2016 5:23pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Mine (145,000 miles....) has always been a noisier TD5 and has always been a bit clattery at idle but over the last few months had gotten steadily a bit noisier and had a pronounced different clatter returning to idle speed at when coming to a stand and sometimes just when it was warm and stood it would do it- a bit of a diesel knock type noise. It went on diagnostics a few weeks ago and one of the injectors was showing up as performing poorly.
It's since had a full reconditioned set....one of which has proceeded to fail (annoyingly) but is being replaced tomorrow under the parts warranty!
Prior to this I had a really annoying rattle at idle that turned out to be one of the 'captive' nuts that hold the engine cover on becoming non-captive and allowing the cover to vibrate and the bolt to rattle about. Sounded 'orrible!
Chris
Post #532984 19th May 2016 5:55pm
yanto
Wales
Thanks for all the comments guys, great site this. I have just filled her up with diesel and put some 2 stroke oil in to see if that helps?? I have an injector loom on the way as I found oil in the ecu plug. May help?
And getting an oil and filter change Saturday.
Post #533014 19th May 2016 8:11pm
dorsetsmith
don't forget brake cleaner for the oil in the loom, for the red ecu plug Thumbs Up
Post #533028 19th May 2016 8:36pm
stigomery
2 stroke oil in the diesel? Is that a common practice?
Post #533048 19th May 2016 9:08pm
yanto
Wales
Thumbs Up
dorsetsmith wrote:
don't forget brake cleaner for the oil in the loom ecu red Thumbs Up
Post #533058 19th May 2016 9:27pm
yanto
Wales
Some are for and some are against. Plenty to read about it on the net.
Post #533059 19th May 2016 9:28pm
srod
Could try a bit of brake cleaner in the diesel while you are at it?
Post #533079 19th May 2016 10:19pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Clatter probably means the injector clearances need resetting.
Post #533282 20th May 2016 9:27pm
