![]() | Home > Td5 > Another one from me sorry |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
What sort of rattely?
Like tin heat shield loose underneeth or engine tappety rattely or interior trim clip loose rattely just to suggest a few? Dont worry about lots of questions, thats what helps build knowlage! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
where does it sound like its coming from?
I have a 2000 TD5 CSW so can compare. I live west of Cardiff. |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
Definitely from the engine. Almost like a heavy diesel knock.
Ian. |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
My td5 does the same on light throttle openings when cold. Diesel clatter. It disappears when you accelerate and goes away almost completely after a couple of miles.
I don't know if it's a sign of a problem or not, but it's always been like it and I've had for 4 years. It had a service at a local Land Rover specialist and the never mentioned it. I just assumed they all did it. My wife's freelander 2 does it too, but it's much better soundproofed so you hardly notice it. 2002 td5 90 county hardtop |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
Mine (new to me, 76,000) makes a fair racket, sounds a bit tappety/clattery but to be honest I put it down to Land Rover Defender Td5 Engine Syndrome...
I've nothing to compare it to but whilst I'm over sensitive to any noise, like the current low whine (is that the drive shaft/gearbox/diffs/...) I think I can over analyse these things... So... Current clattery noise is just normal until someone tells me different ![]() I suspect our two vehicles are making the same (normal) noise... |
That would be good. Where about are you? You can have a drive of mine and see how it goes. Ian |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
Mine (145,000 miles....) has always been a noisier TD5 and has always been a bit clattery at idle but over the last few months had gotten steadily a bit noisier and had a pronounced different clatter returning to idle speed at when coming to a stand and sometimes just when it was warm and stood it would do it- a bit of a diesel knock type noise. It went on diagnostics a few weeks ago and one of the injectors was showing up as performing poorly.
It's since had a full reconditioned set....one of which has proceeded to fail (annoyingly) but is being replaced tomorrow under the parts warranty! Prior to this I had a really annoying rattle at idle that turned out to be one of the 'captive' nuts that hold the engine cover on becoming non-captive and allowing the cover to vibrate and the bolt to rattle about. Sounded 'orrible! Chris |
Thanks for all the comments guys, great site this. I have just filled her up with diesel and put some 2 stroke oil in to see if that helps?? I have an injector loom on the way as I found oil in the ecu plug. May help?
And getting an oil and filter change Saturday. |
don't forget brake cleaner for the oil in the loom, for the red ecu plug
![]() Last edited by dorsetsmith on 20th May 2016 7:44am. Edited 1 time in total |
2 stroke oil in the diesel? Is that a common practice?
Some are for and some are against. Plenty to read about it on the net. |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Could try a bit of brake cleaner in the diesel while you are at it?
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Clatter probably means the injector clearances need resetting.
