![]() | Home > Puma (Tdci) > Rear door hinge |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Unfortunately, as far as I know you are correct. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Still spare wheel mounted? ![]() |
Nipalong Member Since: 08 Jul 2015 Location: Kent Posts: 29 ![]() ![]() ![]() |
My rear door rattled, it turned out that the lock was not lined up correctly, and that the roof of my station wagon was not aligned properly, went in and had it sorted, water tight and no rattlenow
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 ![]() ![]() ![]() |
I had this thumping noise for a little while and only just got round to spraying and fitting new door hinges, the newer design don't seem as robust as the old bolt and bush design. When removing two out of the three had sheared, luckily the door had been hung via the top hinge creating a cup in the joint or I would of needed a new door.
I would check immediately, just loosen the body side, one at a time and check the hinge is still connected. |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
I should have said I replaced just the top hinge and it is lovely now. All the rattles that I thought could be the rear seats or the rear windows were in fact, the top hinge all along.
Now in love with my Landy again. |
