Home > Puma (Tdci) > Rear door hinge
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Rear door hinge
Just discovered that the mega rattle from the back is caused by loads of play in the rear door top hinge. On my old landys you could repair or adjust but there doesn't immediately seem to be a solution for the Tdci other than replacement.
Does anyone know differently please?
Post #532510 17th May 2016 10:01pm
nickhodgson
Unfortunately, as far as I know you are correct. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #532559 18th May 2016 6:33am
hornet
Re: Rear door hinge
Nevillerover wrote:
Just discovered that the mega rattle from the back is caused by loads of play in the rear door top hinge. [..]
Still spare wheel mounted? Thumbs Up
Post #533185 20th May 2016 2:42pm
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
My rear door rattled, it turned out that the lock was not lined up correctly, and that the roof of my station wagon was not aligned properly, went in and had it sorted, water tight and no rattlenow Very Happy
Post #547682 10th Jul 2016 11:24pm
Greg L
Scotland 2000 Defender 90 Td5 SW Epsom Green
I had this thumping noise for a little while and only just got round to spraying and fitting new door hinges, the newer design don't seem as robust as the old bolt and bush design. When removing two out of the three had sheared, luckily the door had been hung via the top hinge creating a cup in the joint or I would of needed a new door.
I would check immediately, just loosen the body side, one at a time and check the hinge is still connected.
Post #551729 27th Jul 2016 9:35pm
Nevillerover
I should have said I replaced just the top hinge and it is lovely now. All the rattles that I thought could be the rear seats or the rear windows were in fact, the top hinge all along.
Now in love with my Landy again.
Post #551740 27th Jul 2016 10:08pm
