![]() | Home > Puma (Tdci) > Raised air intake question...? |
| haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178
It's screwed in using hex screws.
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
2 self tapping screws 130's have feeling's as well you know
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
wot they said
2 self tappers into the A-pillar. Some people replace them with rivnuts and in my experience the self tappers can work loose after a while. If you're fitting them, don't drill the hole too big (or they won't bite) and watch the wires behind the pillar + New Defender 110 First Edition |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18036
Mine (mil spec) is attached with four stainless socket head capscrews with Nylocs on the inside of the pillar, plus sealant round the screws.
As others have said, however you fix it watch the cables up the inside of the pillar, and also look out for the reinforcing webs on the inside of the pillar (avoid them when drilling). |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
On that specific snorkel it doesn't use self tappers (unlike most snorkels) but it uses M6 bolts..... I took mine off not long ago
Glyn |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
selotape
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Velcro did it for me!!! Treat every day as if it is your last....one day you will be right!! |
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
You guys are so un technical it makes me scream....
I use bluetack!!! |
Two self tapping hex head screws/bolts hold the stainless steel bracket to the A pillar. You have to drill a 5mm hole and the screws/bolts cut their own 6mm thread into the ally Click image to enlarge The position the the bolts is determined by the stainless steel bracket that is bolted to the RAI Click image to enlarge Full instructions can be found here PS there are two pages of photographs https://www.defender2.net/gallery/thumbnails.php?album=26 130's have feeling's as well you know |
[quote="...
PS there are two pages of photographs https://www.defender2.net/gallery/thumbnails.php?album=26[/quote] He's my hero No seriously + New Defender 110 First Edition |
