Home > Puma (Tdci) > Raised air intake question...?
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
How does the Land Rover raised air intake attach to the A-piller....?
Does it just screw into the piller, or something else....!
Post #47211 3rd Dec 2010 10:04am
haworthj
It's screwed in using hex screws.
Post #47212 3rd Dec 2010 10:12am
AndrewS
2 self tapping screws 130's have feeling's as well you know Smile
Post #47218 3rd Dec 2010 10:53am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
wot they said Thumbs Up
2 self tappers into the A-pillar. Some people replace them with rivnuts and in my experience the self tappers can work loose after a while.
If you're fitting them, don't drill the hole too big (or they won't bite) and watch the wires behind the pillar Wink One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #47237 3rd Dec 2010 12:38pm
Mine (mil spec) is attached with four stainless socket head capscrews with Nylocs on the inside of the pillar, plus sealant round the screws.
As others have said, however you fix it watch the cables up the inside of the pillar, and also look out for the reinforcing webs on the inside of the pillar (avoid them when drilling).
Post #47239 3rd Dec 2010 12:48pm
Glynparry25
On that specific snorkel it doesn't use self tappers (unlike most snorkels) but it uses M6 bolts..... I took mine off not long ago Wink
Glyn Sheep
Post #47287 3rd Dec 2010 5:53pm
mse
selotape Rolling with laughter Mike
Post #47382 4th Dec 2010 10:09am
K9F
Velcro did it for me!!! Razz If you go through life with your head in the sand....all people will see is an ar5e!!
Post #47392 4th Dec 2010 11:12am
K9F
K9F wrote:
Velcro did it for me!!! As long as you limit your speed to 43MPH!!!Razz
Post #47393 4th Dec 2010 11:12am
mse
Thumbs Up Mike
Post #47455 5th Dec 2010 10:35am
You guys are so un technical it makes me scream....
I use bluetack!!! Rolling with laughter Rolling with laughter
Post #47463 5th Dec 2010 12:39pm
AndrewS
Re: Raised air intake question...?
Two self tapping hex head screws/bolts hold the stainless steel bracket to the A pillar. You have to drill a 5mm hole and the screws/bolts cut their own 6mm thread into the ally
The position the the bolts is determined by the stainless steel bracket that is bolted to the RAI
Full instructions can be found here
PS there are two pages of photographs Thumbs Up
https://www.defender2.net/gallery/thumbnails.php?album=26 130's have feeling's as well you know Smile
Post #47467 5th Dec 2010 1:14pm
alantd
[quote="...
https://www.defender2.net/gallery/thumbnails.php?album=26[/quote]
He's my hero Bow down
No seriously Very Happy One that started out as a 2.4 TDCi 110 XS
Post #47653 7th Dec 2010 12:01am
