![]() | Home > Wheels & Tyres > Bowler or ZU 16"... |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
We run Zu rims with 255/85/16. They use standard alloy wheel nuts.
Have no experience of Bowler wheels but they should work with standard alloy wheel nuts. We are happy with the Zu's and 255/85/16 BFG. It would be down to your personal taste which wheel looks best in your eyes. Brendan |
Guytn Member Since: 09 Apr 2009 Location: Torhout Posts: 24 ![]() ![]() ![]() |
Hello,
The ZU is no option any longer because I would need to put spacers... What could you guys propose to put as a rim? - Alloy rim - goes with standard defender wheel nuts - enough offset to put 255/85R16 Thanks! |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 312 ![]() ![]() |
Bowlers use standard alloy wheel nuts. I am running 265's on bowler 16" and they are spot on. You will not regret it.
Pete |
Am slightly confused. We run 255/85/16 on Zu rims without issue. Why would you need spacers? Offset of Zu Rims is 11mm. I can not readily find offset of Bowler rims. Bowler rims are 8" wide whereas the Zu rims are 7" wide. According to car bibles.com the minimum 16" rim for a 255/85 tyre is 7" and maximum is 8.5" Brendan |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
I have run this combination (ZU with 255/85 16) both with and without spacers, and there are no clearance issues. As Brendan said, the ZUīs have an 11mm offset which makes them the widest stanced 7" rim on my list. I too do not have the offset dimension for the 16" Bowler, so cannot compare. I genuinely prefer the ZUīs, and one the reasons is they are the easiest wheel to clean Iīve even had on any vehicle.
![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
I have Zu's with BFG AT 265/75R16 without any issues. Very happy with them and indeed rims are very easy to clean, no clearance issues at all.
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Arran73 Member Since: 25 Mar 2013 Location: Commugny, Switzerland Posts: 133 ![]() ![]() |
Got ZU's with standard size tired and spacers
![]() Click image to enlarge 1997 Defender 90 300tdi |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
I believe Bowlers are ET 10 so would be the same as the Zu's so no need for spacers. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Bowlers, No question,,
![]() ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
mattp Member Since: 24 Aug 2015 Location: Melbourne Posts: 38 ![]() ![]() ![]() |
Bowlers are ET15 |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
When I enquired about Bowler 16 inch rims with Bowler Manufacturing a few months back I was advised the offset is ET 10.
Ahh sorry, I was referring to the 18"
