Home > Wheels & Tyres > Bowler or ZU 16"...
Guytn
Belgium 2015 Defender 110 Puma 2.2 DCPU Montalcino Red
Bowler or ZU 16"...
Hello!
I'm looking to buy a set of Bowler rims - 16" or a set of ZU 16".
Can both rims be used with standard LR bolts or do you need a special type of bolts?
What rim would you prefer with an MT tyre? (255x85R16)
Post #529440 5th May 2016 10:43pm
leeds
We run Zu rims with 255/85/16. They use standard alloy wheel nuts.
Have no experience of Bowler wheels but they should work with standard alloy wheel nuts.
We are happy with the Zu's and 255/85/16 BFG.
It would be down to your personal taste which wheel looks best in your eyes.
Brendan
Post #529586 6th May 2016 6:37pm
Guytn
Hello,
The ZU is no option any longer because I would need to put spacers...
What could you guys propose to put as a rim?
- Alloy rim
- goes with standard defender wheel nuts
- enough offset to put 255/85R16
Thanks!
Post #530246 9th May 2016 8:48pm
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Bowlers use standard alloy wheel nuts. I am running 265's on bowler 16" and they are spot on. You will not regret it.
Pete
Post #530255 9th May 2016 9:03pm
leeds
Guytn wrote:
Hello,
- Alloy rim
Thanks!
Am slightly confused.
We run 255/85/16 on Zu rims without issue. Why would you need spacers?
Offset of Zu Rims is 11mm.
I can not readily find offset of Bowler rims.
Bowler rims are 8" wide whereas the Zu rims are 7" wide.
According to car bibles.com the minimum 16" rim for a 255/85 tyre is 7" and maximum is 8.5"
Brendan
Post #530286 9th May 2016 10:06pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I have run this combination (ZU with 255/85 16) both with and without spacers, and there are no clearance issues. As Brendan said, the ZUīs have an 11mm offset which makes them the widest stanced 7" rim on my list. I too do not have the offset dimension for the 16" Bowler, so cannot compare. I genuinely prefer the ZUīs, and one the reasons is they are the easiest wheel to clean Iīve even had on any vehicle. Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #530319 10th May 2016 5:37am
VeeTee
Netherlands
I have Zu's with BFG AT 265/75R16 without any issues. Very happy with them and indeed rims are very easy to clean, no clearance issues at all. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #530332 10th May 2016 8:31am
Arran73
Got ZU's with standard size tired and spacers
 1997 Defender 90 300tdi
Post #531043 12th May 2016 5:44pm
JOW240725
I believe Bowlers are ET 10 so would be the same as the Zu's so no need for spacers. James
Instagram @suffolk_rovers
Post #531047 12th May 2016 5:53pm
TJ101
Bowlers, No question,, Whistle But i could be bias, after trying a loads of different rims over the years
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #531158 12th May 2016 11:31pm
mattp
Australia 2016 Defender 110 Puma 2.2 SW Santorini Black
Bowlers are ET15
Post #535625 29th May 2016 2:15pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
When I enquired about Bowler 16 inch rims with Bowler Manufacturing a few months back I was advised the offset is ET 10.
Post #535804 30th May 2016 10:44am
mattp
Ahh sorry, I was referring to the 18"
Post #535809 30th May 2016 10:53am
